This code sequence can be used in either a shared object or dynamic executable. This sequence is used when referencing a TLS variable bound within the same object as the reference. Because the dynamic tlsoffset can be bound at link-edit time, only one call to __tls_get_addr() is required per function call for all symbols referenced via the LD code sequence.
Table 8–3 SPARC: 32-bit and 64-bit Local Dynamic Thread-Local Variable Access Codes|
Outstanding Relocations: 32-bit |
Symbol |
GOT[n] GOT[n + 1] |
R_SPARC_TLS_DTPMOD32 <none> |
x1 |
Outstanding Relocations: 64-bit |
Symbol |
GOT[n] GOT[n + 1] |
R_SPARC_TLS_DTPMOD64 <none> |
x1 |
The first sethi and add instructions generate R_SPARC_TLS_LDM_HI22 and R_SPARC_TLS_LDM_LO10 relocations respectively. These relocations instruct the link-editor to allocate space in the global offset table to hold a TLS_index structure for the current object. The link-editor processes this relocation by substituting the GOT-relative offset for the new GOT entry.
Since the load object index is not known until runtime, a R_SPARC_TLS_DTPMOD32 relocation is created, and the ti_tlsoffset field of the TLS_index structure is zero filled.
The second add and the call instruction are tagged with the R_SPARC_TLS_LDM_ADD and R_SPARC_TLS_LDM_CALL relocations respectively.
The following sethi and or instructions generate the R_SPARC_LDO_HIX22 and R_SPARC_TLS_LDO_LOX10 relocations, respectively. The TLS offset for each local symbol is known at link-edit time, therefore these values are filled in directly. The add instruction is tagged with the R_SPARC_TLS_LDO_ADD relocation.
When a procedure references more then one local symbol, the compiler generates code to obtain the base address of the TLS block once. This base address is then used to calculate the address of each symbol without a separate library call.
The register containing the TLS object address in the add instruction tagged by the R_SPARC_TLS_LDO_ADD must be the first register in the instruction sequence. This permits the link-editor to identify the register during a code transformation.
