This code sequence can only be used in a dynamic executable. It can reference a TLS variable defined in either the executable or any shared libraries loaded at process startup. This model can not reference TLS variables from shared libraries loaded after process startup.
Table 8–4 SPARC: 32-bit Initial Executable Thread-Local Variable Access Codes|
Outstanding Relocations |
Symbol |
GOT[n] |
R_SPARC_TLS_TPOFF32 |
x |
The sethi and or instructions generate R_SPARC_TLS_IE_HI22 and R_SPARC_TLS_IE_LO10 relocations, respectively. These relocations instruct the link-editor to create space in the global offset table to store the static TLS offset for symbol x. A R_SPARC_TLS_TPOFF32 relocation is left outstanding against the GOT for the runtime linker to fill in with the negative static TLS offset for symbol x. The ld and the add instructions are tagged with the R_SPARC_TLS_IE_LD and R_SPARC_TLS_IE_ADD relocations respectively.
The register used as the GOT-pointer for the add instruction tagged by the R_SPARC_TLS_IE_ADD relocation must be the first register in the instruction. This permits the link-editor to identify the GOT-pointer register during a code transformation.
