Check your current operating environment for the packages in the following table, which are required to use Solaris Live Upgrade. If packages in the column for your release are missing, use the pkgadd command to add the packages.
Table 34–2 Required Packages for Solaris Live Upgrade
Solaris 2.6 Release |
Solaris 7 Release |
Solaris 8 Release |
SUNWadmap |
SUNWadmap |
SUNWadmap |
SUNWadmc |
SUNWadmc |
SUNWadmc |
SUNWjvrt |
SUNWjvrt |
SUNWj2rt |
SUNWlibC |
SUNWlibC |
SUNWlibC |
SUNWadmfw |
SUNWbzip |
SUNWmfrun |
SUNWloc |
To check for packages on your system, type the following command.
% pkginfo [[package_name]] |
