The following example shows how to do a full backup of the root (/) file system. The system in this example is brought to single-user mode before the backup. The following ufsdump options are included:
0 specifies a 0 level dump (or a full backup).
u specifies that the /etc/dumpdates file is updated with the date of this backup.
c identifies a cartridge tape device.
f /dev/rmt/0 identifies the tape device.
/ is the file system being backed up.
For example:
# init 0
ok boot -s
# ufsdump 0ucf /dev/rmt/0 /
DUMP: Date of this level 0 dump: Tue Oct 07 16:23:08 2003
DUMP: Date of last level 0 dump: the epoch
DUMP: Dumping /dev/rdsk/c0t0d0s0 (starbug:/) to /dev/rmt/0.
DUMP: Mapping (Pass I) [regular files]
DUMP: Mapping (Pass II) [directories]
DUMP: Writing 63 Kilobyte records
DUMP: Estimated 296644 blocks (144.85MB).
DUMP: Dumping (Pass III) [directories]
DUMP: Dumping (Pass IV) [regular files]
DUMP: Tape rewinding
DUMP: 296224 blocks (144.64MB) on 1 volume at 424 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 0 dump on Tue Oct 07 16:23:08 2003
# ufsrestore tf /dev/rmt/0
2 .
3 ./lost+found
3776 ./usr
7552 ./var
11328 ./export
15104 ./export/home
18880 ./etc
22656 ./etc/default
22657 ./etc/default/sys-suspend
22673 ./etc/default/cron
22674 ./etc/default/devfsadm
22675 ./etc/default/dhcpagent
22676 ./etc/default/fs
22677 ./etc/default/inetinit
22678 ./etc/default/kbd
22679 ./etc/default/mpathd
22680 ./etc/default/nfslogd
22681 ./etc/default/passwd
# (Press Control-D to bring system to run level 3)
