The following example shows how to do an incremental backup of the root (/) file system in single-user mode. The following ufsdump options are included:
9 specifies a 9 level dump (or an incremental backup).
u specifies that the /etc/dumpdates file is updated with the date of this backup.
c identifies a cartridge tape device.
f /dev/rmt/0 identifies the tape device.
/ is the file system being backed up.
# init 0
ok boot -s
Rebooting with command: boot -s
SunOS Release 5.9 Generic May 2002
Copyright 1983-2003 Sun Microsystems, Inc. All rights reserved.
# ufsdump 9ucf /dev/rmt/0 /
DUMP: Date of this level 9 dump: Mon Oct 06 12:36:10 2003
DUMP: Date of last level 0 dump: Wed Oct 08 10:12:13 2003
DUMP: Dumping /dev/rdsk/c0t0d0s0 (starbug:/) to /dev/rmt/0.
DUMP: Mapping (Pass I) [regular files]
DUMP: Mapping (Pass II) [directories]
DUMP: Writing 63 Kilobyte records
DUMP: Estimated 335844 blocks (163.99MB).
DUMP: Dumping (Pass III) [directories]
DUMP: Dumping (Pass IV) [regular files]
DUMP: 335410 blocks (163.77MB) on 1 volume at 893 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 9 dump on Mon Oct 06 12:36:10 2003
# ufsrestore tf /dev/rmt/0
2 .
3 ./lost+found
5696 ./usr
11392 ./var
17088 ./export
22784 ./export/home
28480 ./opt
5697 ./etc
11393 ./etc/default
11394 ./etc/default/sys-suspend
11429 ./etc/default/cron
11430 ./etc/default/devfsadm
11431 ./etc/default/dhcpagent
11432 ./etc/default/fs
11433 ./etc/default/inetinit
11434 ./etc/default/kbd
11435 ./etc/default/nfslogd
11436 ./etc/default/passwd
11437 ./etc/default/tar
