By writing your own shell scripts and using the commands shown in the following table, you can easily set up and manage your diskless client environment.
Table 7–3 Diskless Client Commands
Command |
Subcommand |
Task |
/usr/sadm/bin/smosservice |
add |
Add OS services |
delete |
Delete OS services |
list |
List OS services |
patch |
Manage OS service patches |
/usr/sadm/bin/smdiskless |
add |
Add a diskless client to an OS server |
delete |
Delete a diskless client from an OS server |
list |
List the diskless clients on an OS server |
modify |
Modify the attributes of a diskless client |
You can obtain help on these commands in two ways:
Use the -h option when you type the command, subcommand, and required options. For example, to display the usage statement for smdiskless add type the following:
% /usr/sadm/bin/smdiskless add -p my-password -u my-user-name -- -h |
View the smdiskless(1M) or smosservice(1M) man pages.
