System Administration Guide: Basic Administration
x86: Detaching PCI Adapter Cards
A PCI adapter card that is hosting nonvital system resources can be removed if the device driver supports hot-plugging. A PCI adapter card is not detachable if it is a vital system resource. For a PCI adapter card to be detachable the following conditions must be met:
For example, if a system has only one Ethernet card installed in it, the Ethernet card cannot be detached without losing the network connection. This detachment requires additional layered software support to keep the network connection active.
x86: Attaching PCI Adapter Cards
A PCI adapter card can be added to the system as long as the following conditions are met:
For step-by-step instructions on adding or removing a PCI adapter card, see x86: PCI Hot-Plugging With the cfgadm Command.
