System Administration Guide: Basic Administration
Setting Up a Package Keystore
In previous Solaris releases, you could download the patch management tools and create a Java keystore, for use by PatchPro, by importing the certificates with the keytool command.
If your system already has a populated Java keystore, you can now export the Sun Microsystems root CA certificate from the Java keystore with the keytool command. Then, use the pkgadm command to import this certificate into the package keystore.
After the Root CA certificate is imported into the package keystore, you can use the pkgadd and patchadd commands to add signed packages and patches to your system.
Note –
The Sun Microsystems root-level certificates are only required when adding Sun-signed patches and packages.
For step-by-step instructions on importing certificates into the package keystore, see How to Import a Trusted Certificate into the Package Keystore (pkgadm addcert).
For complete instructions on adding signed packages with the pkgadd command, see Adding and Removing Signed Packages (Task Map).
