You can obtain Sun's trusted certificates for adding signed packages and patches in the following ways:
Java keystore – Import Sun's Root CA certificate that is included by default in the Java keystore when you install the Solaris release.
Sun's Public Key Infrastructure (PKI) site – If you do not have a Java keystore available on your system, you can import the certificates from this site.
PatchPro's keystore – If you have installed PatchPro for adding signed patches with the smpatch command, you can import Sun's Root CA certificate from the Java keystore.
