A desktop entry file is a data file that provides information about an item in a menu. The desktop entry file specifies the details for the item such as a name, a command to run, an icon, and so on. The desktop entry file also contains keywords which determine the location of the item in the menu hierarchy. Desktop entry files have a .desktop file extension.
The following is a sample desktop entry file:
[Desktop Entry] Encoding=UTF-8 Name=Calculator Comment=Perform simple calculations Exec=gnome-calculator Icon=gnome-calc3.png Terminal=false Type=Application X-GNOME-DocPath=gnome-calculator/gnome-calculator.xml Categories=GNOME;Application;Utility;
Table 2–3 describes the most important keys in desktop entry files.
Table 2–3 Desktop Entry Keys|
Desktop Entry Key |
Description |
Encoding |
Specifies the encoding of the desktop entry file. |
Name |
Specifies the name of the item. This name is displayed on the item in the menu. |
Comment |
Specifies a short description of the item. The comment is displayed as a tooltip when you point to the item in the menu. |
Exec |
Specifies a command to execute when you choose the item from the menu. |
Icon |
Specifies the filename of an icon that represents the item. Does not specify the path to the filename, or the filename extension. |
Terminal |
Specifies whether the command in the Exec key runs in a terminal window. If the value is true the command runs in a terminal window. If the command does not create a window in which to run, the value of this key must be true. |
Type |
Specifies the type of item. This value is one of the following:
X-GNOME-DocPath |
Specifies the help file to display when you choose Help on application-name from the menu item popup menu. |
Categories |
Specifies the keywords that describe the item. The keywords are separated with semicolons (;). To see a list of the standard category keywords, see the following URL: http://www.freedesktop.org/standards/VFolderDesktops.txt The vfolder information files map the keywords to menus. |
For more information on the keys in desktop entry files, see the following URL:
http://www.freedesktop.org/standards/desktop-entry-spec/desktop-entry-spec.html
Panel launchers and desktop objects also use desktop entry files. The desktop entry files for launchers and desktop objects provide the same information as for items in a menu. For example, the desktop entry files provide the command to run when a user chooses the launcher or object.
