A directory entry file is a data file that provides information about a menu. The directory entry file specifies the details for the menu such as a name, a tooltip, and an icon. Directory entry files have a .directory file extension.
The following is a sample directory entry file:
[Desktop Entry] Name=Accessories Comment=Accessories menu Icon=gnome-util.png Type=Directory
Table 2–4 describes the most important keys in directory entry files.
Table 2–4 Directory Entry Keys|
Directory Entry Key |
Description |
Name |
Specifies the name of the menu. This name is displayed on the menu. |
Comment |
Specifies a short description of the menu. The comment is displayed as a tooltip when you point to the menu. |
Icon |
Specifies the filename of an icon that represents the menu. Does not specify the path to the filename, or the filename extension. |
Type |
Specifies the type of menu. The value of this key is always Directory. |
