If +/- is used in /etc/passwd, /etc/shadow, and /etc/group files, you need to modify the nsswitch.conf file to insure compatibility.
NIS+. To provide +/- semantics with NIS+, change the passwd and groups sources to compat. Then, add a passwd_compat: nisplus entry to the nsswitch.conf file after the passwd or group entry as shown below.
passwd: compat passwd_compat: nisplus group: compat group_compat: nisplus |
The above specifies that client routines obtain their network information from /etc files and NIS+ tables as indicated by the +/- entries in the files.
NIS. To provide the same syntax as in the Sun Operating Environment 4.x release, change the passwd and groups sources to compat.
passwd: compat group: compat |
Specifies the /etc files and NIS maps as indicated by the +/- entries in the files.
Users working on a client machine being served by an NIS+ server running in NIS compatibility mode cannot run ypcat on the netgroup table. Doing so gives you results as if the table were empty even if the table has entries.
