System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
IPv6 and Solaris Naming Services
NIS, NIS+ and LDAP support storing IPv6 data, as well as using IPv6 transports for protocol traffic. DNS supports the use of IPv6 transports on the client side only. As of BIND version 8.3.3, the DNS server does not support IPv6 transports.
The nsswitch.conf file controls search criteria for IPv6 addresses. IPv6 increases the IP address size from 32 bits to 128 bits to support more levels of addressing hierarchy. A larger address size provides a greater number of addressable nodes. For more information about IPv6, its configuration and implementation, see System Administration Guide: IP Services.
Use the new ipnodes source for IPv6 addresses. The /etc/inet/ipnodes file stores both IPv4 and IPv6 addresses. The /etc/inet/ipnodes file uses the same format convention as the /etc/hosts file.
IPv6 aware naming services use the new ipnodes source for its search forwarding. For instance, if LDAP is aware of IPv6 addresses, specify the following.
ipnodes: ldap [NOTFOUND=return] files
Caution – Caution –
Potential delay issues:
