Port numbers can be any number from 1 to 65535. Keep the following in mind when choosing a port number for your Sun ONE Directory Server.
The standard Sun ONE Directory Server (LDAP) port number is 389.
Port 636 is reserved for LDAP over SSL. Therefore, do not use port number 636 for your standard LDAP configuration, even if 636 is not already in use. You can also use LDAP over TLS on the standard LDAP port.
Port numbers between 1 and 1024 have been assigned to various services by the Internet Assigned Numbers Authority. Do not use port numbers below 1024 other than 389 or 636 for directory services as they will conflict with other services. Additionally, port numbers below 1024 are accessible by root only.
Sun ONE Directory Server must run as root when using either port 389 or 636.
Make sure the ports you choose are not already in use. Additionally, if you are using both LDAP and LDAPS communications, make sure the port numbers chosen for these two types of access are not identical.
If the LDAP naming service clients are using SSL encryption, you must use the default port numbers 389 and 636, so that the server runs as root. See Transport Layer Security (TLS) for more information.
For information on how to set up LDAP over SSL (LDAPS) for the Sun ONE Directory Server, see the administration guide for the version of Sun ONE Directory Server that you are using.
