Problem: The server times out.
Cause: When the N2L server refreshes a map, the result might be a large LDAP directory access. If the Sun ONE Directory Server is not correctly configured, this operation might time out before completion.
Solution: To avoid directory server timeouts, modify the Sun ONE Directory Server attributes manually or by running the idsconfig command. See Common LDAP Error Messages and N2L Best Practices With Sun ONE Directory Server for details.
