The mapping file, NISLDAPmapping, is complex. Many potential errors might cause the mapping to behave in unexpected ways. Use the following techniques to resolve such problems.
Console Message Displays When ypserv -ir (or -Ir) Runs
Problem: A simple message is displayed on the console and the server exits (a detailed description is written to syslog).
Cause: The syntax of the mapping file might be incorrect.
Solution: Check and correct the syntax in the NISLDAPmapping file.
NIS Daemon Exits at Startup
Problem: When ypserv or other NIS daemons run, an LDAP-related error message is logged and the daemon exits.
Cause: The cause might be one of the following:
The LDAP server cannot be contacted.
An entry found in an NIS map or in the DIT is incompatible with the mapping specified.
An attempt to read or write to the LDAP server returns an error.
Solution: Examine the error log on the LDAP server. See the LDAP errors that are listed in Common LDAP Error Messages.
Unexpected Results From NIS Operations
Problem: NIS operations do not return the expected results, but no errors are logged.
Cause: Incorrect entries might exist in the LDAP or NIS maps, which results in mappings not completing as intended.
Solution: Check and correct entries in the LDAP DIT and in the N2L versions of the NIS maps.
Check that the correct entries exist in the LDAP DIT, and correct the entries as needed.
If you are using the Sun ONE Directory Server, start the management console by running directoryserver startconsole.
Check that the N2L versions of the NIS maps in the /var/yp directory contain the expected entries by comparing the newly generated map to the original map. Correct entries as needed.
# cd /var/yp/domainname # makedbm -u test.byname # makedbm -u LDAP_test.byname |
Be aware of the following when checking the output for the maps:
The order of entries might not be the same in both files.
Use the sort command before comparing output.
The use of white space might not be the same in both files.
Use the diff -b command when comparing output.
Processing Order of NIS Maps
Problem: Object class violations occur.
Cause: When the ypserv -i command is run, each NIS map is read and its contents are written into the DIT. Several maps might contribute attributes to the same DIT object. Generally, one map creates most of the object, including all the object's MUST attributes. Other maps contribute additional MAY attributes.
Maps are processed in the same order that nisLDAPobjectDN attributes appear in the NISLDAPmapping file. If maps containing MAY attributes get processed before maps containing MUST attributes, then object class violations occur. See Error 65 in Common LDAP Error Messages for more information about this error.
Solution: Reorder the nisLDAPobjectDN attributes so that maps are processed in the correct order.
As a temporary fix, rerun the ypserv -i command several times. Each time the command is executed, more of the LDAP entry is built up.
Mapping in such a way that all of an object's MUST attributes cannot be created from at least one map is not supported.
