System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Example pam.conf File for pam_ldap
# Authentication management
# login service (explicit because of pam_dial_auth)
login auth required pam_authtok_get.so.1
login auth required pam_dhkeys.so.1
login auth required pam_dial_auth.so.1
login auth sufficient pam_unix_auth.so.1
login auth required pam_ldap.so.1 try_first_pass
# rlogin service (explicit because of pam_rhost_auth)
rlogin auth sufficient pam_rhosts_auth.so.1
rlogin auth required pam_authtok_get.so.1
rlogin auth required pam_dhkeys.so.1
rlogin auth sufficient pam_unix_auth.so.1
rlogin auth required pam_ldap.so.1 try_first_pass
# rsh service (explicit because of pam_rhost_auth)
rsh auth sufficient pam_rhosts_auth.so.1
rsh auth required pam_authtok_get.so.1
rsh auth required pam_dhkeys.so.1
rsh auth sufficient pam_unix_auth.so.1
rsh auth required pam_ldap.so.1 try_first_pass
# PPP service (explicit because of pam_dial_auth)
ppp auth required pam_authtok_get.so.1
ppp auth required pam_dhkeys.so.1
ppp auth required pam_dial_auth.so.1
ppp auth sufficient pam_unix_auth.so.1
ppp auth required pam_ldap.so.1 try_first_pass
# Default definitions for Authentication management
# Used when service name is not explicitly mentioned for authentication
other auth required pam_authtok_get.so.1
other auth required pam_dhkeys.so.1
other auth sufficient pam_unix_auth.so.1
other auth required pam_ldap.so.1 try_first_pass
# passwd command (explicit because of a different authentication module)
passwd auth sufficient pam_passwd_auth.so.1
passwd auth required pam_ldap.so.1 try_first_pass
# cron service (explicit because of non-usage of pam_roles.so.1)
cron account required pam_projects.so.1
cron account required pam_unix_account.so.1
# Default definition for Account management
# Used when service name is not explicitly mentioned for account
management
other account requisite pam_roles.so.1
other account required pam_projects.so.1
other account required pam_unix_account.so.1
# Default definition for Session management
# Used when service name is not explicitly mentioned for session
management
other session required pam_unix_session.so.1
# Default definition for Password management
# Used when service name is not explicitly mentioned for password
management
other password required pam_dhkeys.so.1
other password required pam_authtok_get.so.1
other password required pam_authtok_check.so.1
other password sufficient pam_authtok_store.so.1
other password required pam_ldap.so.1
# Support for Kerberos V5 authentication (uncomment to use Kerberos)
#rlogin auth optional pam_krb5.so.1 try_first_pass
#login auth optional pam_krb5.so.1 try_first_pass
#other auth optional pam_krb5.so.1 try_first_pass
#cron account optional pam_krb5.so.1
#other account optional pam_krb5.so.1
#other session optional pam_krb5.so.1
#other password optional pam_krb5.so.1 try_first_pass
- © 2010, Oracle Corporation and/or its affiliates
