There are two sets of LDAP-related commands in the Solaris operating environment. One set is the general LDAP tools, which do not require the client to be configured with LDAP naming services. The second set uses the common LDAP configuration on the client and therefore can only be used if the client is configured to use LDAP as its naming service.
LDAP command-line tools support a common set of options, including authentication and bind parameters.
These commands can be used to manipulate directory entries directly. The ldapsearch(1), ldapmodify(1), ldapadd(1), and ldapdelete(1) tools support a common text-based format for representing directory information called the LDAP Data Interchange Format (LDIF).
Tool |
Function |
Used to create entries in LDAP containers from the corresponding /etc files. This tool allows populating the directory from files. For example, it reads /etc/passwd format file and populates passwd entries in the directory. |
Used to list contents of various services from the directory. |
Used to set up Sun ONE Directory Server to serve LDAP naming service clients. |
