Problem |
Bug ID 4855527, In the Editing profile
window, Title and Command tab, the menu options for the
drop-down menu Dynamically-set title do not work. PROMPT_COMMAND=$'echo -ne "\\033]0;${USER}@${HOSTNAME}: ${PWD}\\007"' PS1=$'[\\u@\\h \\W]\\$ ' USER=`id -un` On Linux /etc/bashrc sets the required environment variables, but does not set these variables for the Solaris operating environment. Hence, the dynamically-set title and the shell prompt do not work in the Solaris operating environment. |
Solution |
As a workaround you can set the required environment variable by executing scripts for the various shells. bash shell: Set the following in bashrc:
case $TERM in
xterm*)
PS1="\[\033]0;\u@\h: \w\007\]bash\\$ "
PS1="bash\\$ "
esac
(or)
USER=`/usr/xpg4/bin/id -un`
export USER
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME}: ${PWD}\007"'
ksh shell: Add the following in the ~.profile file:
mycd () {
cd "${@}"; echo "\033]0;${USER}@${HOSTNAME}: ${PWD}\007\c"
alias cd=mycd
csh shell: Set the following in cshrc:
switch ($TERM)
case "xterm*":
set host=`hostname`
alias cd 'cd \!*; echo -n "^[]0;${user}@${host}:
${cwd}^Gcsh% "'
breaksw
default:
set prompt='csh% '
breaksw
endsw
The '^[' and '^G' characters in the prompt string are single characters for ESC and BEL. You can enter these characters using Ctrl+v+ESC and Ctrl+v+g. |
