Solution
You do not need to
use the -o and -p options to perform a standard
setup of the ScrollKeeper database. These options are required only in the
following situations:
The ScrollKeeper database must be installed in a location
other than the standard location. For example, setting up diskless clients.
Use the -p path option to
specify the location of the ScrollKeeper database, where path is an empty directory. The scrollkeeper-rebuilddb command will not proceed if you specify a populated path for this
option.
The OMF files must be read from a location other than the
standard location. The standard location for OMF files is specified in the /etc/scrollkeeper.conf file.
Use the -o path option to
specify the location of the OMF files. Specify the complete pathname, for
example, /usr/share/omf. If you specify a partial pathname,
for example, /usr/share, the scrollkeeper-rebuilddb command will take a long time, produce many warnings, and may crash.
The following example shows how to use the -o and -p options to set up the ScrollKeeper database
for diskless clients:
# scrollkeeper-rebuilddb \
-p /export/root/clone/Solaris_9/\
sun4u/var/gnome/lib/scrollkeeper \
-o /export/exec/Solaris_9_sparc.all/\
usr/share/omf
