The following problems affect European locales:
Problem |
Affects the pt_BR.ISO8859-1 locale. The Start menu is not localized. |
Solution |
This problem will be fixed in a future release. |
Problem |
Affects the pt_BR.ISO8859-1 and pt_BR.UTF-8 locales. In the XScreenSaver Properties dialog, localization characters are missing, In the pt_BR.UTF-8 locale incorrect characters are displayed, for example Cryllic characters. |
Solution |
Problem |
Affects Russian locales. The keyboard shortcut Ctrl+Spacebar to select and change the input method window does not work on the x86 architecture edition of the Solaris operating environment. |
Solution |
Use the mouse to select and change the input method window. |
