The following problems affect Asian locales:
9.4.4 Different Date Format in the Solaris Operating Environment
9.4.6 Printing Out From gedit in the Solaris 8 Operating Environment
9.4.7 Cannot Print Japanese Characters With Default Font in gedit
Problem |
Bug ID 4785550, affects
the Part of the IBM/NEC extended character and special characters are not displayed. |
Solution |
Known limitation. |
Problem |
Bug ID 4826184, affects Japanese locales. You cannot open ISO-2022–JP encoded files
in the |
Solution |
This problem will be fixed in a future release. |
Problem |
Bug ID 4824884, affects Japanese locales. A core dump sometimes occurs when you use Nautilus to copy or link to a file that was created in a different locale. |
Solution |
Log in to the locale in which the file was created, then copy the file or create a link to the file. |
Problem |
Bug ID 4781611, affects the ja_JP.UTF–8 locale. When there are multiple input contexts on the same top-level application window, the input method window is repeatedly flushed. |
Solution |
