Solaris 9 9/04 Installation Guide
To Create a sysidcfg Configuration File
  1. Create a file called sysidcfg in a text editor.
  2. Type the sysidcfg keywords you want.
  3. Save the sysidcfg file.
    Note –
    If you create more than one sysidcfg file, you must save each file in a separate directory or on a separate diskette.
  4. Make the sysidcfg file available to clients through the following:
    • A shared NFS file system. Use add_install_client(1M) with the -p option to set up the system to install from the network.
    • The root (/) directory on a UFS diskette or PCFS diskette.
Example 7–10 SPARC: sysidcfg File
The following is an example of a sysidcfg file for a SPARC based system. The host name, IP address, and netmask of this system has been preconfigured by editing the name service. Because all of the system configuration information is preconfigured in this file, you can use a custom JumpStart profile to perform a custom JumpStart installation.
system_locale=en_US
timezone=US/Central
terminal=sun-cmd
timeserver=localhost
name_service=NIS {domain_name=marquee.central.example.com
                  name_server=connor(172.31.112.3)}
root_password=m4QPOWNY
network_interface=le0 {hostname=feron
                       default_route=192.168.88.1
                       ip_address=192.168.88.210
                       netmask=255.255.0.0
                       protocol_ipv6=no}
security_policy=kerberos {default_realm=example.COM
                          admin_server=krbadmin.example.COM
                          kdc=kdc1.example.COM,
                          kdc2.example.COM}
Example 7–11 x86: sysidcfg File
The following sample sysidcfg file is for a group of x86 based systems that all use the same type of keyboard, graphics cards, and pointing devices. The device information (keyboard, display, and pointer) was obtained by running the kdmconfig(1M) command with the -d option. If the following example sysidcfg file is used, a prompt that asks you to select a language (system_locale) is displayed before installation can proceed.
keyboard=ATKBD {layout=US-English}
display=ati {size=15-inch}
pointer=MS-S
timezone=US/Central
timeserver=connor
terminal=ibm-pc
                  name_server=connor(172.25.112.3)}
root_password=URFUni9
Example 7–12 sysidcfg File for Configuring Multiple Interfaces
In the following sample sysidcfg file, configuration information is specified for both the eri0 and eri1 network interfaces. The eri0 interface is configured as the primary network interface, and eri1 is configured as a secondary network interface.
timezone=US/Pacific
system_locale=C
terminal=xterms
network_interface=eri0 {primary
                        hostname=feron
                        ip_address=192.168.2.7
                        netmask=255.255.255.0
                        protocol_ipv6=no
                        default_route=192.168.2.1}
network_interface=eri1 {hostname=feron-b
                        ip_address=192.168.3.8
                        protocol_ipv6=no
                        default_route=192.168.3.1}
root_password=JE2C35JGZi4B2
security_policy=none
name_service=NIS {domain_name=domain.example.com
                  name_server=nis-server(192.168.2.200)}
