Table 7–2 lists the keywords you can use to configure system information in the sysidcfg file.
Table 7–2 Keywords You Can Use in sysidcfg|
Configuration Information |
Keyword |
Name service, domain name, name server | |
Network interface, host name, Internet Protocol (IP) address, netmask, DHCP, IPv6 | |
Root password | |
Security policy | |
Language in which to display the install program and desktop | |
Terminal type | |
Time zone | |
Date and time | |
x86: Monitor type | |
x86: Keyboard language, keyboard layout | |
x86: Graphics card, screen size, color depth, display resolution | |
x86: Pointing device, number of buttons, IRQ level |
The following sections describe the keywords you can use in the sysidcfg file.
You can use the name_service keyword to configure the name service, the domain name, and the name server for the system. The following sample shows the general syntax for the name_service keyword.
name_service=name-service {domain_name=domain-name
name_server=name-server
optional-keyword=value}
Choose only one value for name_service. Include all or none of the domain_name,name_server, or optional keywords, as needed. If no keywords are used, omit the curly braces {}.
The following sections describe the keyword syntax to configure the system to use a specific name service.
Use the following syntax to configure the system to use the NIS name service.
name_service=NIS {domain_name=domain-name
name_server=hostname(ip-address)}
Specifies the domain name
Specifies the host name of the name server
Specifies the IP address of the name server
The following example specifies a NIS server with the domain name west.example.com. The server's host name is timber, and the server IP address is 192.168.2.1.
name_service=NIS {domain_name=west.example.com
name_server=timber(192.168.2.1)}
For more information about the NIS name service, see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
name_service=NIS+ {domain_name=domain-name
The following example specifies a NIS+ server with the domain name west.example.com. The server's host name is timber, and the server IP address is 192.168.2.1.
name_service=NIS+ {domain_name=west.example.com
For more information about the NIS+ name service, see System Administration Guide: Naming and Directory Services (FNS and NIS+).
Use the following syntax to configure the system to use DNS.
name_service=DNS {domain_name=domain-name
name_server=ip-address,ip-address,ip-address
search=domain-name,domain-name,domain-name,
domain-name,domain-name,domain-name}
Specifies the domain name.
Specifies the IP address of the DNS server. You can specify up to three IP addresses as values for the name_server keyword.
(Optional) Specifies additional domains to search for name service information. You can specify up to six domain names to search. The total length of each search entry cannot exceed 250 characters.
The following example specifies a DNS server with the domain name west.example.com. The server IP addresses are 10.0.1.10 and 10.0.1.20. example.com and east.example.com are listed as additional domains to search for name service information.
name_service=DNS {domain_name=west.example.com
name_server=10.0.1.10,10.0.1.20
search=example.com,east.example.com}
For more information about the DNS name service, see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
Use the following syntax to configure the system to use LDAP.
name_service=LDAP {domain_name=domain_name
profile=profile_name profile_server=ip_address
proxy_dn="proxy_bind_dn" proxy_password=password}
Specifies the domain name of the LDAP server.
Specifies the name of the LDAP profile you want to use to configure the system.
Specifies the IP address of the LDAP profile server.
(Optional) Specifies the proxy bind distinguished name. You must enclose the proxy_bind_dn value in double quotes.
(Optional) Specifies the client proxy password.
The following example specifies an LDAP server with the following configuration information.
The domain name is west.example.com.
The installation program uses the LDAP profile that is named default to configure the system.
The IP address of the LDAP server is 172.221.2.1.
The proxy bind distinguished name includes the following information.
The common name for the entry is proxyagent.
The organizational unit is profile.
The proxy domain includes the west, example, and com domain components.
The poxy password is password.
name_service=LDAP {domain_name=west.example.com
profile=default
profile_server=172.31.2.1
proxy_dn="cn=proxyagent,ou=profile,
dc=west,dc=example,dc=com"
For more information about how to use LDAP, see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
Use the network_interface keyword to perform the following tasks.
Specify a host name
Specify an IP address
Specify a netmask value
Use DHCP to configure the network interface
Enable IPv6 on the network interface
The following sections describe how to use the network_interface keyword to configure the system interfaces.
To turn off networking for the system, set the network_interface value to none. For example:
network_interface=none |
You can use the network_interface keyword to configure a single interface in the following ways.
With DHCP – You can use a DHCP server on your network to configure the network interface. For more information on how to use a DHCP server during your installation, see Preconfiguring System Configuration Information With the DHCP Service (Tasks).
To use the DHCP server to configure a single interface on the system, use the following syntax for the network_interface keyword.
network_interface=PRIMARY or value
{dhcp protocol_ipv6=yes-or-no}
Instructs the installation program to configure the first up, non-loopback interface that is found on the system. The order is the same as the order that is displayed with the ifconfig command. If no interfaces are up, then the first non-loopback interface is used. If no non-loopback interfaces are found, then the system is non-networked.
Instructs the installation program to configure a specific interface, such as hme0 or eri1.
Instructs the installation program to configure the system to either use IPv6 or to not use IPv6.
For WAN boot installations, you must set the value of protocol_ipv6=no.
Without DHCP – If you do not want to use DHCP to configure the network interface, you can specify the configuration information in the sysidcfg file. To instruct the installation program to configure a single interface on the system without using DHCP, use the following syntax.
{hostname=host_name
default_route=ip_address
ip_address=ip_address
netmask=netmask
protocol_ipv6=yes_or_no}
Instructs the installation program to configure the first up, non-loopback interface that is found on the system. The order is the same as the order that is displayed with the ifconfig command. If no interfaces are up, then the first non-loopback interface is used. If no non-loopback interfaces are found, then the system is not networked.
Do not use the PRIMARY keyword value if you want to configure multiple interfaces.
(Optional) Specifies the host name of the system.
(Optional) Specifies the IP address of the default router. If you want the installation program to detect the router by using the ICMP router discovery protocol, omit this keyword.
If the installation program cannot detect the router, you are prompted for the router information during the installation.
(Optional) Specifies the IP address of the system.
(Optional) Specifies the netmask value for the system.
(Optional) Instructs the installation program to configure the system to either use IPv6 or to not use IPv6.
To perform an unattended custom JumpStart installation, you must specify a value for the protocol_ipv6 keyword.
Include any combination or none of the hostname, ip_address, and netmask keywords, as needed. If you do not use any of these keywords, omit the curly braces ({}).
The following example instructs the installation program to use DHCP to configure the eri0 network interface. IPv6 support is not enabled.
network_interface=eri0 {dhcp protocol_ipv6=no}
The following example configures the interface eri0 with the following settings.
The host name is set to host1.
The IP address is set to 172.31.88.100.
The netmask is set to 255.255.255.0.
IPv6 support is not enabled on the interface.
network_interface=eri0 {hostname=host1 ip_address=172.31.88.100
netmask=255.255.255.0 protocol_ipv6=no}
You can configure multiple network interfaces in your sysidcfg file. For each interface that you want to configure, include a network_interface entry in the sysidcfg file.
You can use the network_interface keyword to configure multiple interfaces in the following ways.
With DHCP – You can use a DHCP server on your network to configure a network interface. For more information on how to use a DHCP server during your installation, see Preconfiguring System Configuration Information With the DHCP Service (Tasks).
To use the DHCP server to configure a network interface on the system, use the following syntax for the network_interface keyword.
network_interface=value {primary
(Optional) Specifies value as the primary interface.
Without DHCP – If you do not want to use DHCP to configure the network interface, you can specify the configuration information in the sysidcfg file. To instruct the installation program to configure multiple interfaces without using DHCP, use the following syntax.
network_interface=value {primary hostname=host_name
netmask=netmask
In the same sysidcfg file, you can use DHCP to configure certain interfaces, while also specifying the configuration information for other interfaces in the sysidcfg file.
In the following example, the network interfaces eri0 and eri1 are configured in the following way.
eri0 is configured by using the DHCP server. IPv6 support is not enabled on eri0.
eri1 is the primary network interface. The host name is set to host1, and the IP address is set to 172.31.88.100. The netmask is set to 255.255.255.0. IPv6 support is not enabled on eri1.
network_interface=eri1 {primary hostname=host1
protocol_ipv6=no}
You can specify the root password to the system in the sysidcfg file. To specify the root password, use the root_password keyword with the following syntax.
root_password=encrypted-password |
encrypted-password is the encrypted password as it appears in the /etc/shadow file.
You can use the security_policy keyword in your sysidcfg file to configure your system to use the Kerberos network authentication protocol. If you want to configure the system to use Kerberos, use the following syntax.
security_policy=kerberos {default_realm=FQDN
admin_server=FQDN kdc=FQDN1, FQDN2, FQDN3}
FQDN specifies the fully qualified domain name of the Kerberos default realm, the administration server, or key distribution center (KDC). You must specify at least one, but no more than three, key distribution centers.
If you do not want to set the security policy for the system, set security_policy=NONE.
For more information about the Kerberos network authentication protocol, see System Administration Guide: Security Services.
The following example configures the system to use Kerberos with the following information.
The Kerberos default realm is example.COM.
The Kerberos administration server is krbadmin.example.COM.
The two key distribution centers are kdc1.example.COM and kdc2.example.COM.
{default_realm=example.COM
admin_server=krbadmin.example.COM
kdc=kdc1.example.COM,
kdc2.example.COM}
You can use the system_locale keyword to specify the language in which to display the install program and desktop. Use the following syntax to specify a locale.
system_locale=locale |
locale specifies the language you want the system to use to display the installation panels and screens. For a list of valid locale values, see the /usr/lib/locale directory or Appendix D, Locale Values (Reference).
You can use the terminal keyword to specify the terminal type for the system. Use the following syntax to specify the terminal type.
terminal=terminal_type |
terminal_type specifies the terminal type for the system. For a list of valid terminal values, see the subdirectories in the /usr/share/lib/terminfo directory.
You can set the time zone for the system with the timezone keyword. Use the following syntax.
timezone=timezone |
In the previous example, timezone specifies the time zone value for the sytem. The directories and files in the /usr/share/lib/zoneinfo directory provide the valid time zone values. The timezone value is the name of the path relative to the /usr/share/lib/zoneinfo directory. You can also specify any valid Olson time zone.
In the following example, the system time zone is set to mountain standard time in the United States.
timezone=US/Mountain |
The installation program configures the system to use the time zone information in /usr/share/lib/zoneinfo/US/Mountain.
You can use the timeserver keyword to specify the system that sets the date and time on the system you want to install.
Do not set timeserver=hostname or ip-address if you are running a name service.
Choose one of the following methods to set the timeserver keyword.
To configure the system to serve as its own time server, set timeserver=localhost. If you specify localhost as the time server, the system's time is assumed to be correct.
To specify another system as the time server, specify either the host name or the IP address of the time server with the timeserver keyword. Use the following syntax.
timeserver=hostname or ip-address |
hostname is the host name of the time server system. ip-address specifies the IP address of the time server.
For x86-based systems, you can configure the monitor information with the monitor keyword. Use the following syntax with the monitor keyword.
monitor=monitor_type |
To set the value for the monitor keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the monitor keyword, and include this line in the sysidcfg file.
For more information, see the kdmconfig(1M) man page.
For x86-based systems, you can configure the keyboard language and layout information with the keyboard keyword. Use the following syntax with the keyboard keyword.
keyboard=keyboard_language {layout=value}
To set the value for the keyboard keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the keyboard keyword, and include this line in the sysidcfg file.
For x86-based systems, you can configure the following information with the display keyword.
Graphics card
Screen size
Color depth
Display resolution
Use the following syntax with the display keyword.
display=graphics_card {size=screen_size
depth=color_depth
resolution=screen_resolution}
To set the appropriate values for the display keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the display keyword, and include this line in the sysidcfg file.
For x86-based systems, you can configure the following mouse information with the pointer keyword.
Pointing device
Number of buttons
IRQ level
Use the following syntax with the pointer keyword.
pointer=pointing_device {nbuttons=number_buttons irq=value}
To set the value for the pointer keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the pointer keyword, and include this line in the sysidcfg file.
