Solaris Volume Manager Administration Guide
Deploying Small Servers
Distributed computing environments, from ISPs to geographically distributed sales offices to telecommunication service providers, often need to deploy similar or identical servers at multiple locations. These servers might provide router or firewall services, email services, DNS caches, Usenet (Network News) servers, DHCP services, or other services best provided at a variety of locations. These small servers have several characteristics in common:
As a starting point, consider a Netra with a single SCSI bus and two internal disks—an off-the-shelf configuration, and a good starting point for distributed servers. Solaris Volume Manager could easily be used to mirror some or all of the slices, thus providing redundant storage to help guard against disk failure. See the following figure for an example.
Figure 23–1 Small System Configuration
Diagram shows how a single system with a single SCSI
controller can mirror two disks for redundant storage.
A configuration like this example might include mirrors for the root (/), /usr, swap, /var, and /export file systems, plus state database replicas (one per disk). As such, a failure of either side of any of the mirrors would not necessarily result in system failure, and up to five discrete failures could possibly be tolerated. However, the system is not sufficiently protected against disk or slice failure. A variety of potential failures could result in a complete system failure, requiring operator intervention.
While this configuration does help provide some protection against catastrophic disk failure, it exposes key possible single points of failure:
A “Best Practices” approach would be to modify the configuration by adding one more controller and one more hard drive. The resulting configuration could be far more resilient.
