Verify whether the hot spare is currently being used by using one of the following methods:
From the Enhanced Storage tool within the Solaris Management Console, open the Hot Spare Pools node and select a hot spare pool. Choose Action->Properties, then choose the Hot Spares panel and follow the instructions. For more information, see the online help.
Use the following form of the metastat command:
metastat hot-spare-pool-name |
See the metastat(1M) man page.
To replace the hot spare, use one of the following methods:
Use the following form of the metahs command:
metahs -r hot-spare-pool-name current-hot-spare replacement-hot-spare |
Specifies to replace disks in the hot spare pool named.
Is the name of the hot spare pool, or the special keyword all to change all hot spare pool associations.
Is the name of the current hot spare that will be replaced.
Is the name of the slice to take the place of the current hot spare in the named pools.
See the metahs(1M) man page for more information.
# metastat hsp003 hsp003: 1 hot spare c0t2d0s2 Broken 5600 blocks # metahs -r hsp003 c0t2d0s2 c3t1d0s2 hsp003: Hotspare c0t2d0s2 is replaced with c3t1d0s2 |
In this example, the metastat command makes sure that the hot spare is not in use. The metahs -r command replaces hot spare /dev/dsk/c0t2d0s2 with /dev/dsk/c3t1d0s2 in the hot spare pool hsp003.
# metahs -r all c1t0d0s2 c3t1d0s2 hsp001: Hotspare c1t0d0s2 is replaced with c3t1d0s2 hsp002: Hotspare c1t0d0s2 is replaced with c3t1d0s2 hsp003: Hotspare c1t0d0s2 is replaced with c3t1d0s2 |
In this example, the keyword all replaces hot spare /dev/dsk/c1t0d0s2 with /dev/dsk/c3t1d0s2 in all its associated hot spare pools.
