The following task map identifies the procedures needed to manage Solaris Volume Manager state database replicas.
Task |
Description |
Instructions |
Create state database replicas |
Use the Solaris Volume Manager GUI or the metadb -a command to create state database replicas. | |
Check the status of state database replicas |
Use the Solaris Volume Manager GUI or the metadb command to check the status of existing replicas. | |
Delete state database replicas. |
Use the Solaris Volume Manager GUI or the metadb -d command to delete state database replicas. |
