If you upgraded from Solstice DiskSuite to Solaris Volume Manager and you have state database replicas sharing slices with file systems or logical volumes (as opposed to on separate slices), do not delete existing replicas and replace them with new default replicas in the same location.
The default state database replica size in Solaris Volume Manager is 8192 blocks, while the default size in Solstice DiskSuite was 1034 blocks. If you delete a default-sized state database replica from Solstice DiskSuite, and then add a new default-sized replica with Solaris Volume Manager, you will overwrite the first 7158 blocks of any file system that occupies the rest of the shared slice, thus destroying the data.
Do not replace default-sized (1034 block) state database replicas from Solstice DiskSuite with default-sized Solaris Volume Manager replicas (8192 blocks) on a slice shared with a file system. If you do, the new replicas will overwrite the beginning of your file system and corrupt it.
Do not place state database replicas on fabric-attached storage, SANs, or other storage that is not directly attached to the system. Replicas must be on storage devices that are available at the same point in the boot process as traditional SCSI or IDE drives.
Check Prerequisites for Creating Solaris Volume Manager Components.
To create state database replicas, use one of the following methods:
From the Enhanced Storage tool within the Solaris Management Console, open the State Database Replicas node. Choose Action->Create Replicas and follow the instructions. For more information, see the online help.
Use the following form of the metadb command. See the metadb(1M) man page for more information.
metadb -a -c n -l nnnn -f ctds-of-slice |
-a specifies to add a state database replica.
-f specifies to force the operation, even if no replicas exist.
-c n specifies the number of replicas to add to the specified slice.
-l nnnn specifies the size of the new replicas, in blocks.
ctds-of-slice specifies the name of the component that will hold the replica.
Use the -f flag to force the addition of the initial replicas.
# metadb -a -f c0t0d0s7 # metadb flags first blk block count ... a u 16 8192 /dev/dsk/c0t0d0s7 |
The -a option adds the additional state database replica to the system, and the -f option forces the creation of the first replica (and may be omitted when you add supplemental replicas to the system).
# metadb -a -c 2 c1t3d0s1 # metadb flags first blk block count ... a u 16 8192 /dev/dsk/c1t3d0s1 a u 8208 8192 /dev/dsk/c1t3d0s1 |
The -a option adds additional state database replicas to the system. The -c 2 option places two replicas on the specified slice. The metadb command checks that the replicas are active, as indicated by the -a.
You can also specify the size of the state database replica with the -l option, followed by the number of blocks. However, the default size of 8192 should be appropriate for virtually all configurations, including those configurations with thousands of logical volumes.
If you are replacing existing state database replicas, you might need to specify a replica size. Particularly if you have existing state database replicas (on a system upgraded from Solstice DiskSuite, perhaps) that share a slice with a file system, you must replace existing replicas with other replicas of the same size or add new replicas in a different location.
# metadb -a -c 3 -l 1034 c0t0d0s7 # metadb flags first blk block count ... a u 16 1034 /dev/dsk/c0t0d0s7 a u 1050 1034 /dev/dsk/c0t0d0s7 a u 2084 1034 /dev/dsk/c0t0d0s7 |
The -a option adds the additional state database replica to the system, and the -l option specifies the length in blocks of the replica to add.
