You can set up terminals and modems with the Solaris Management Console's Serial Ports Tool, Admintool, or the SAF commands.
The SAF is the tool that is used to administer terminals, modems, and other network devices. The top-level SAF program is the Service Access Controller (SAC). The SAC controls port monitors that you administer through the sacadm command. Each port monitor can manage one or more ports.
You administer the services associated with ports through the pmadm command. While services provided through SAC can differ from network to network, the SAC and its administrative commands, sacadm and pmadm, are network independent.
The following table describes the SAF control hierarchy. The sacadm command is used to administer the SAC, which controls the ttymon and listen port monitors.
The services of ttymon and listen are in turn controlled by the pmadm command. One instance of ttymon can service multiple ports. One instance of listen can provide multiple services on a network interface.
Table 12–1 SAF Control Hierarchy|
Function |
Program |
Description |
Overall Administration |
sacadm |
Command for adding and removing port monitors |
Service Access Controller |
sac |
SAF's master program |
Port Monitors |
ttymon listen |
Monitors serial port login requests Monitors requests for network services |
Port Monitor Service Administrator |
pmadm |
Command for controlling port monitors services |
Services |
logins, remote procedure calls, other |
Services to which the SAF provides access |
Console Administration |
console login |
The console is automatically set up with an entry in the /etc/inittab file that uses ttymon-express mode. Do not use the pmadm or sacadm to manage the console directly. For more information, see ttymon and the Console Port. |
