Before you create a terminfo entry for a printer, you should first make sure none of the existing terminfo entries will support the printer. To do so, try to set up the printer with an entry for a similar printer, if there is one.
Log in as superuser, lp, or assume an equivalent role on the print server.
Determine a terminfo entry name for the printer.
The directories in the /usr/share/lib/terminfo directory contain all the valid terminfo entries. Use them as a guide for choosing a name for the printer.
Create a terminfo entry file for the printer.
Table 7–2 shows the items you must define in the terminfo entry to add a new printer to the LP print service. For more details about the structure of the terminfo database, see terminfo(4).
To help you start writing a new terminfo entry, use the infocmp command to save an existing terminfo entry to a file. This is helpful if there is a terminfo entry that is similar to one you want to create. For example, the following command saves the ps entry to the ps_cust file, which will become the new terminfo entry.
infocmp ps > ps_cust
Compile the terminfo entry file into the terminfo database.
# tic terminfo_entry |
terminfo_entry |
The terminfo entry file you created. |
Check for the new terminfo entry file in the /usr/share/lib/terminfo directory.
