List files, displaying the most recently created or changed files first, by using the ls -t command.
$ ls -t [directory] |
-t |
Sorts files by latest time stamp first. |
directory |
Identifies the directory you want to search. |
The following example shows how to use the ls -tl command to locate the most recently created or changed files within the /var/adm directory. The sulog file was created or edited most recently.
$ ls -tl /var/adm total 134 -rw------- 1 root root 315 Sep 24 14:00 sulog -r--r--r-- 1 root other 350700 Sep 22 11:04 lastlog -rw-r--r-- 1 root bin 4464 Sep 22 11:04 utmpx -rw-r--r-- 1 adm adm 20088 Sep 22 11:04 wtmpx -rw-r--r-- 1 root other 0 Sep 19 03:10 messages -rw-r--r-- 1 root other 0 Sep 12 03:10 messages.0 -rw-r--r-- 1 root root 11510 Sep 10 16:13 messages.1 -rw-r--r-- 1 root root 0 Sep 10 16:12 vold.log drwxr-xr-x 2 root sys 512 Sep 10 15:33 sm.bin drwxrwxr-x 5 adm adm 512 Sep 10 15:19 acct drwxrwxr-x 2 adm sys 512 Sep 10 15:19 sa -rw------- 1 uucp bin 0 Sep 10 15:17 aculog -rw-rw-rw- 1 root bin 0 Sep 10 15:17 spellhist drwxr-xr-x 2 adm adm 512 Sep 10 15:17 log drwxr-xr-x 2 adm adm 512 Sep 10 15:17 passwd |
