Turn on file system quotas.
# quotaon [-v] -a filesystem ... |
-v |
Displays a message for each file system after quotas are turned on. |
-a |
Turns on quotas for all file systems with an rq entry in the /etc/vfstab file. |
filesystem ... |
Turns on quotas for one or more file systems that you specify. More than one file system is specified by separating each file system name with a space. |
The following example shows how to turn quotas on for the file systems on the /dev/dsk/c0t4d0s7 and /dev/dsk/c0t3d0s7 slices.
# quotaon -v /dev/dsk/c0t4d0s7 /dev/dsk/c0t3d0s7 /dev/dsk/c0t4d0s7: quotas turned on /dev/dsk/c0t3d0s7: quotas turned on |
