You should back up all file systems that are critical to users, including file systems that change frequently. The following tables provide general guidelines on the file systems to back up for standalone systems and servers.
Table 22–2 File Systems to Back Up for Standalone Systems
File System to Back Up |
Description |
Back Up Interval |
root (/) – slice 0 |
This file system contains the kernel and possibly the /var directory. The /var directory might include frequently modified files such as mail and accounting files. |
At regular intervals such as weekly or daily |
/usr – slice 6, /opt |
The installation of new software and new commands typically affects the /usr and /opt file systems. The /opt directory is either part of root (/) or is its own file system. |
Occasionally |
/export/home – slice 7 |
This file system contains the directories and subdirectories of all users on the standalone system. |
More often than root (/) or /usr, perhaps as often as once a day, depending on your site's needs |
/export , /var, or other file systems |
During installation of Solaris software, you might have created these file systems. |
As your site requires |
Table 22–3 File Systems to Back Up for Servers
Description |
Back Up Interval |
This file system contains the kernel and executables. |
Once a day to once a month depending on your site's needs. If you frequently add and remove users and systems on the network, you have to change configuration files in this file system. In this case, you should do a full backup of the root (/) file system at intervals between once a week and once a month. If your site keeps user mail in the /var/mail directory on a mail server, which client systems then mount, you might want to back up root (/) daily. Or, backup the /var directory, if it is a separate file system. |
/export – slice 3 |
This file system can contain the kernel and executables for diskless clients. |
Once a day to once a month, depending on your site's needs. Because the information in this file system is similar to the server's root directory in slice 0, the file system does not change frequently. You need to back up this file system only occasionally, unless your site delivers mail to client systems. Then, you should back up /export more frequently. |
An optional file system generally used to store non-system software. |
Once a day to once a month, depending on your site's needs. These file systems are fairly static and need to be backed up once a week to once a month. |
This file system contains the home directories of all the users on the system. The files in this file system are volatile. |
Once a day to once a week. |
