The following task map describes the procedures associated with restoring files and file systems.
Task |
Description |
For Instructions |
Prepare to restore files and file systems |
Identify the file systems or files to be restored, the tape device, and how you will restore them. | |
Determine which tapes to use |
Refer to your backup tapes to find the date of the last backup that contains the file or file system that you need to restore. | |
Restore files |
Choose one of the following restore methods: |
Restore files interactively–Use this method when you are unsure of the file names because you can browse the media contents and select individual files and directories. | |
Restore files noninteractively–Use this method when you already know the few file names to be restored. | |
Restore a file system – Use this method when you get a new disk drive or as part of a recovery procedure. | |
Restore the root (/) or /usr file systems |
Restoring the root (/) or /usr file systems involves booting the system from a local CD or the network. |
