System Administration Guide: Devices and File Systems
Choosing Which Media to Use
You typically back up Solaris systems by using the following tape media:
You can perform backups with diskettes, but doing so is time-consuming and cumbersome.
The media that you choose depends on the availability of the equipment that supports it and of the media (usually tape) that you use to store the files. Although you must do the backup from a local system, you can write the files to a remote device.
The following table shows typical tape devices that are used for backing up file systems. shows The storage capacity for each device depends on the type of drive and the data being written to the tape.
Table 28–1 Media Storage Capacities
Backup Media
Storage Capacity
1/2-inch reel tape
140 Mbytes (6250 bpi)
2.5-Gbyte 1/4–inch cartridge (QIC) tape
2.5 Gbytes
DDS3 4-mm cartridge tape (DAT)
12–24 Gbytes
14-Gbyte 8-mm cartridge tape
14 Gbytes
DLT 7000 1/2-inch cartridge tape
35–70 Gbytes
