The following are general steps for backing up file systems by using the ufsdump command. The examples show specific uses of options and arguments.
Become superuser or assume an equivalent role.
Bring the system to run level S (single-user mode).
For example:
# shutdown -g30 -y |
(Optional) Check the file system for consistency.
For example:
# fsck -m /dev/rdsk/c0t0d0s7 |
The fsck -m command checks for the consistency of file systems. For example, power failures can leave files in an inconsistent state. For more information on the fsck command, see Chapter 20, Checking UFS File System Consistency (Tasks).
If you need to back up file systems to a remote tape drive, follow these steps:
On the system to which the tape drive is attached (the tape server), add the following entry to its /.rhosts file.
host root |
The host entry specifies the name of the system on which you will run the ufsdump command to perform the backup.
On the tape server, verify that the host added to the /.rhosts file is accessible through the name service.
Identify the device name of the tape drive.
The default tape drive is the /dev/rmt/0 device.
Insert a tape that is write-enabled into the tape drive.
Back up file systems.
# ufsdump options arguments filenames |
You can back up file systems or directories or files within file systems. For information on backing up individual files, see tar(1) or cpio(1).
The following examples show how to use the most common ufsdump options and arguments:
For other ufsdump options and arguments, see Chapter 26, UFS Backup and Restore Commands (Reference).
If prompted, remove the tape and insert the next tape volume.
Label each tape with the volume number, dump level, date, system name, disk slice, and file system.
Bring the system back to run level 3 by pressing Control-D.
Verify that the backup was successful.
# ufsrestore tf device-name |
The following example shows how to do a full backup of the root (/) file system. The system in this example is brought to single-user mode before the backup. The following ufsdump options are included:
0 specifies a 0 level dump (or a full backup).
u specifies that the /etc/dumpdates file is updated with the date of this backup.
c identifies a cartridge tape device.
f /dev/rmt/0 identifies the tape device.
/ is the file system being backed up.
For example:
# init 0
ok boot -s
# ufsdump 0ucf /dev/rmt/0 /
DUMP: Date of this level 0 dump: Tue Oct 07 16:23:08 2003
DUMP: Date of last level 0 dump: the epoch
DUMP: Dumping /dev/rdsk/c0t0d0s0 (starbug:/) to /dev/rmt/0.
DUMP: Mapping (Pass I) [regular files]
DUMP: Mapping (Pass II) [directories]
DUMP: Writing 63 Kilobyte records
DUMP: Estimated 296644 blocks (144.85MB).
DUMP: Dumping (Pass III) [directories]
DUMP: Dumping (Pass IV) [regular files]
DUMP: Tape rewinding
DUMP: 296224 blocks (144.64MB) on 1 volume at 424 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 0 dump on Tue Oct 07 16:23:08 2003
# ufsrestore tf /dev/rmt/0
2 .
3 ./lost+found
3776 ./usr
7552 ./var
11328 ./export
15104 ./export/home
18880 ./etc
22656 ./etc/default
22657 ./etc/default/sys-suspend
22673 ./etc/default/cron
22674 ./etc/default/devfsadm
22675 ./etc/default/dhcpagent
22676 ./etc/default/fs
22677 ./etc/default/inetinit
22678 ./etc/default/kbd
22679 ./etc/default/mpathd
22680 ./etc/default/nfslogd
22681 ./etc/default/passwd
# (Press Control-D to bring system to run level 3)
The following example shows how to do an incremental backup of the root (/) file system in single-user mode. The following ufsdump options are included:
9 specifies a 9 level dump (or an incremental backup).
# init 0
ok boot -s
Rebooting with command: boot -sSunOS Release 5.9 Generic May 2002
Copyright 1983-2003 Sun Microsystems, Inc. All rights reserved.
# ufsdump 9ucf /dev/rmt/0 /
DUMP: Date of this level 9 dump: Mon Oct 06 12:36:10 2003
DUMP: Date of last level 0 dump: Wed Oct 08 10:12:13 2003
DUMP: Estimated 335844 blocks (163.99MB).
DUMP: 335410 blocks (163.77MB) on 1 volume at 893 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 9 dump on Mon Oct 06 12:36:10 2003
2 .
3 ./lost+found
5696 ./usr
11392 ./var
17088 ./export
22784 ./export/home
28480 ./opt
5697 ./etc
11393 ./etc/default
11394 ./etc/default/sys-suspend
11429 ./etc/default/cron
11430 ./etc/default/devfsadm
11431 ./etc/default/dhcpagent
11432 ./etc/default/fs
11433 ./etc/default/inetinit
11434 ./etc/default/kbd
11435 ./etc/default/nfslogd
11436 ./etc/default/passwd
11437 ./etc/default/tar
The following example shows how to do a full backup of the /export/home/kryten home directory. The following ufsdump options are included:
0 specifies that this is a 0 level dump (or a full backup)
/export/home/kryten is the directory being backed up
# umount /export/home |
# ufsdump 0ucf /dev/rmt/0 /export/home/kryten
DUMP: Date of this level 0 dump: Tue Oct 07 08:41:41 2003
DUMP: Estimated 470 blocks (235KB).
DUMP: 376 blocks (188KB) on 1 volume at 1205 KB/sec
DUMP: DUMP IS DONE
2 .
5 ./export
6 ./export/home
80799 ./export/home/kryten
80800 ./export/home/kryten/filea
80801 ./export/home/kryten/fileb
80802 ./export/home/kryten/filec
80803 ./export/home/kryten/letters
80804 ./export/home/kryten/letters/letter1
80805 ./export/home/kryten/letters/letter2
80806 ./export/home/kryten/letters/letter3
80807 ./export/home/kryten/reports
80808 ./export/home/kryten/reports/reportA
80809 ./export/home/kryten/reports/reportB
80810 ./export/home/kryten/reports/reportC
The following example shows how to do a full backup of a local /export/home file system on a Solaris 9 system (starbug) to a tape device on a remote Solaris 9 system (earth) in single-user mode. The following ufsdump options are included:
f earth:/dev/rmt/0 identifies the remote system name and tape device
/export/home is the file system being backed up.
# ufsdump 0ucf earth:/dev/rmt/0 /export/home
DUMP: Date of this level 0 dump: Mon Oct 06 12:46:50 2003
DUMP: Dumping /dev/rdsk/c0t0d0s7 (starbug:/export/home) to
earth:/dev/rmt/0.
DUMP: Estimated 410 blocks (205KB).
DUMP: 376 blocks (188KB) on 1 volume at 546 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 0 dump on Mon Oct 06 12:46:50 2003
# ufsrestore tf earth:/dev/rmt/0
2 .
3 ./lost+found
4 ./kryten
5 ./kryten/filea
6 ./kryten/fileb
7 ./kryten/filec
8 ./kryten/letters
9 ./kryten/letters/letter1
10 ./kryten/letters/letter2
11 ./kryten/letters/letter3
12 ./kryten/reports
