#! /usr/bin/perl -w
# A sample site customization RCM script.
# When RCM_ENV_FORCE is FALSE this script indicates to RCM that it cannot
# release the tape drive when the tape drive is being used for backup.
# When RCM_ENV_FORCE is TRUE this script allows DR removing a tape drive
# when the tape drive is being used for backup by killing the tape
# backup application.
use strict;
my ($cmd, %dispatch);
$cmd = shift(@ARGV);
# dispatch table for RCM commands
%dispatch = (
"scriptinfo" => \&do_scriptinfo,
"register" => \&do_register,
"resourceinfo" => \&do_resourceinfo,
"queryremove" => \&do_preremove,
"preremove" => \&do_preremove
if (defined($dispatch{$cmd})) {
&{$dispatch{$cmd}};
} else {
exit (2);
sub do_scriptinfo
print "rcm_script_version=1\n";
print "rcm_script_func_info=Tape backup appl script for DR\n";
exit (0);
sub do_register
my ($dir, $f, $errmsg);
$dir = opendir(RMT, "/dev/rmt");
if (!$dir) {
$errmsg = "Unable to open /dev/rmt directory: $!";
print "rcm_failure_reason=$errmsg\n";
exit (1);
while ($f = readdir(RMT)) {
# ignore hidden files and multiple names for the same device
if (($f !~ /^\./) && ($f =~ /^[0-9]+$/)) {
print "rcm_resource_name=/dev/rmt/$f\n";
closedir(RMT);
exit (0);
sub do_resourceinfo
my ($rsrc, $unit);
$rsrc = shift(@ARGV);
if ($rsrc =~ /^\/dev\/rmt\/([0-9]+)$/) {
$unit = $1;
print "rcm_resource_usage_info=Backup Tape Unit Number $unit\n";
exit (0);
} else {
print "rcm_failure_reason=Unknown tape device!\n";
exit (1);
sub do_preremove
my ($rsrc);
# check if backup application is using this resource
#if (the backup application is not running on $rsrc) {
# allow the DR to continue
# exit (0);
# If RCM_ENV_FORCE is FALSE deny the operation.
# If RCM_ENV_FORCE is TRUE kill the backup application in order
# to allow the DR operation to proceed
if ($ENV{RCM_ENV_FORCE} eq 'TRUE') {
if ($cmd eq 'preremove') {
# kill the tape backup application
exit (0);
} else {
# indicate that the tape drive can not be released
# since the device is being used for backup by the
# tape backup application
print "rcm_failure_reason=tape backup in progress pid=...\n"
exit (3);
