System Administration Guide: Devices and File Systems
Application Developer RCM Script (Task Map)
The following task map describes the tasks for an application developer who is creating an RCM script.
Task
Description
For Instructions
1. Identify resources your application uses
Identify the resources (device names) your application uses that you could potentially dynamically remove.
cfgadm(1M)
2. Identify commands to release the resource
Identify the commands for notifying the application to cleanly release the resource from the application.
Application documentation
3. Identify commands for post-removal of the resource
Include the commands for notifying the application of the resource removal.
rcmscript(4)
4. Identify commands if the resource removal fails
Include the commands for notifying the application of the available resource.
rcmscript(4)
5. Write the RCM script
Write the RCM script based on the information identified in the previous tasks.
Tape Backup RCM Script Example
6. Install the RCM script
Add the script to the appropriate script directory.
How to Install an RCM Script
7. Test the RCM script
Test the script by running the script commands manually and by initiating a dynamic reconfiguration operation.
How to Test an RCM Script
