You must be superuser (root) to install or remove an RCM script. Use this table to determine where you should install your RCM script.
Table 6–1 RCM Script Directories|
Directory Location |
Script Type |
/etc/rcm/scripts |
Scripts for specific systems |
/usr/platform/`uname -i`/lib/rcm/scripts |
Scripts for a specific hardware implementation |
/usr/platform/`uname -m`/lib/rcm/scripts |
Scripts for a specific hardware class |
/usr/lib/rcm/scripts |
Scripts for any hardware |
