Keep the following in mind when working with multi-configuration USB devices:
A USB device configuration defines how a device presents itself to the operating system. This is different from system device configurations discussed in other cfgadm sections.
Some USB devices support multiple configurations, but only one configuration can be active at a time.
Multi-configuration devices can be identified by examining the cfgadm -lv output. Nconfigs will be greater than 1.
The default USB configuration is configuration 1. The current configuration is reflected in cfgadm -lv output as Config.
Changes to the default configuration will persist across reboots, hot-removes, and reconfiguration of the device, as long as it is reconnected to the same port.
Make sure the device is not in use.
Change the default USB configuration.
For example:
# cfgadm -x usb_config -o config=2 usb0/4 Setting the device: /devices/pci@1f,0/usb@c,3:4 to USB configuration 2 This operation will suspend activity on the USB device Continue (yes/no)? yes |
Verify the device change.
For example:
# cfgadm -lv usb0/4
Ap_Id Receptacle Occupant Condition Information When Type
Busy Phys_Id
usb0/4 connected unconfigured ok Mfg: Sun 2000
Product: USB-B0B0 aka Robotech
With 6 EPPS High Clk Mode NConfigs: 7 Config: 2 : EVAL Board Setup
unavailable
usb-device n /devices/pci@1f,0/usb@c,3:4
Config now shows 2.
