System Administration Guide: Devices and File Systems
Installing a System With an EFI-Labeled Disk
The Solaris installation utilities automatically recognize disks with EFI labels, but cannot use the Solaris installation utilities to repartition these disks. You must use the format utility to repartition this disk before or after installation. The Solaris Upgrade and Live Upgrade utilities also recognize a disk with an EFI label. However, you cannot boot a system from an EFI-labeled disk.
After the Solaris release is installed on a system with an EFI-labeled disk, the partition table looks similar to the following:
Current partition table (original):
Total disk sectors available: 2576924638 + 16384 (reserved sectors)
Part      Tag    Flag     First Sector          Size          Last Sector
  0       root    wm                34         1.20TB           2576924636
  1 unassigned    wm                 0            0                0
  2 unassigned    wm                 0            0                0
  3 unassigned    wm                 0            0                0
  4 unassigned    wm                 0            0                0
  5 unassigned    wm                 0            0                0
  6 unassigned    wm                 0            0                0
  8   reserved    wm        2576924638         8.00MB           2576941021
