System Administration Guide: Devices and File Systems
Determining Which Slices to Use
When you set up a disk's file systems, you choose not only the size of each slice, but also which slices to use. Your decisions about these matters depend on the configuration of the system to which the disk is attached and the software you want to install on the disk.
System configurations that need disk space are as follows:
Each system configuration can use slices in a different way. The following table lists some examples.
Table 10–4 System Configurations and Slices
Slice
Servers
Standalone Systems
0
root
root
1
swap
swap
2
3
/export
6
/usr
/usr
7
/export/home
/home
For more information about system configurations, see Overview of System Types in System Administration Guide: Basic Administration.
Note –
The Solaris installation program provides default slice sizes based on the software you select for installation.
