System Administration Guide: Devices and File Systems
Chapter 10 Managing Disks (Overview)
This chapter provides overview information about Solaris disk slices and introduces the format utility.
This is a list of overview information in this chapter.
For instructions on how to add a disk to your system, see Chapter 12, SPARC: Adding a Disk (Tasks) or Chapter 13, x86: Adding a Disk (Tasks).
What's New in Disk Management in the Solaris 9 Update Releases?
This section describes new disk management features in this Solaris release.
SPARC: Multiterabyte Disk Support With EFI Disk Label
Solaris 9 4/03 – Provides support for disks that are larger than 1 terabyte on systems that run a 64-bit Solaris kernel.
You can download the EFI specification at http://www.intel.com/technology/efi/main_specification.htm.
The EFI label provides support for physical disks and virtual disk volumes. This release also includes updated disk utilities for managing disks greater than 1 terabyte. The UFS file system is compatible with the EFI disk label, and you can create a UFS file system greater than 1 terabyte. For information on creating a multiterabyte UFS file system, see SPARC: Support of Multiterabyte UFS File Systems.
The unbundled Sun QFS file system is also available if you need to create file systems greater than 1 terabyte. For information on the Sun QFS file system, see http://docs.sun.com/db/doc/816-2542-10.
The Solaris Volume Manager software can also be used to manage disks greater than 1 terabyte in this Solaris release. For information on using Solaris Volume Manager, see Solaris Volume Manager Administration Guide.
The VTOC label is still available for disks less than 1 terabyte in size. If you are only using disks smaller than 1 terabyte on your systems, managing disks will be the same as in previous Solaris releases. In addition, you can use the format-e command to label a disk less than 1 terabyte with an EFI label. For more information, see Example 11–6.
Comparison of the EFI Label and the VTOC Label
The EFI disk label differs from the VTOC disk label in the following ways:
Restrictions of the EFI Disk Label
Keep the following restrictions in mind when determining whether to use disks greater than 1 terabyte is appropriate for your environment:
Installing a System With an EFI-Labeled Disk
The Solaris installation utilities automatically recognize disks with EFI labels, but cannot use the Solaris installation utilities to repartition these disks. You must use the format utility to repartition this disk before or after installation. The Solaris Upgrade and Live Upgrade utilities also recognize a disk with an EFI label. However, you cannot boot a system from an EFI-labeled disk.
After the Solaris release is installed on a system with an EFI-labeled disk, the partition table looks similar to the following:
Current partition table (original):
Total disk sectors available: 2576924638 + 16384 (reserved sectors)
Part      Tag    Flag     First Sector          Size          Last Sector
  0       root    wm                34         1.20TB           2576924636
  1 unassigned    wm                 0            0                0
  2 unassigned    wm                 0            0                0
  3 unassigned    wm                 0            0                0
  4 unassigned    wm                 0            0                0
  5 unassigned    wm                 0            0                0
  6 unassigned    wm                 0            0                0
  8   reserved    wm        2576924638         8.00MB           2576941021
Managing Disks With EFI Disks Labels
Use the following table to locate information on managing disks with EFI disk labels.
Task
For More Information
If the system is already installed, connect the disk to the system and perform a reconfiguration boot.
SPARC: Adding a System Disk or a Secondary Disk (Task Map)
Repartition the disk with the format utility, if necessary.
SPARC: How to Create Disk Slices and Label a Disk
Create disk volumes, and if needed, create soft partitions with Solaris Volume Manager.
Chapter 2, Storage Management Concepts, in Solaris Volume Manager Administration Guide
Create UFS file systems for the new disk with the newfs command.
SPARC: How to Create a UFS File System
Or, create a QFS file system.
http://docs.sun.com/db/coll/20445.2
Cloning a Disk with an EFI Label
In previous Solaris releases, slice 2 (s2) was used to represent the whole disk. You could use the dd command to clone or copy disks by using syntax similar to the following:
dd if=/dev/rdsk/c0t0d0s2 of=/dev/rdsk/c0t2d0s2 bs=128k
Now, you must use a slightly different procedure to clone or copy disks larger than 1 terabyte so that the UUID of cloned disks are unique. For example:
  1. Use the dd command to clone the disk with an EFI label:
    # dd if=/dev/rdsk/c0t0d0 of=/dev/rdsk/c0t2d0 bs=128k
  2. Pipe the prtvtoc output of the disk to be copied to the fmthard command to create a new label for the cloned disk.
    # prtvtoc /dev/rdsk/c0t0d0 | fmthard -s - /dev/rdsk/c0t2d0
Caution – Caution –
If you do not create a new label for the cloned disk, other software products might corrupt data on EFI-labeled disks if they encounter duplicate UUIDs.
Troubleshooting Problems With EFI Disk Labels
Use the following error messages and solutions to troubleshooting problems with EFI-labeled disks.
Error Message
The capacity of this LUN is too large.
Reconfigure this LUN so that it is < 2TB.
Cause
You attempted to create a partition on a SCSI device that is larger than 2 terabytes.
Solution
Create a partition on a SCSI device that is less than 2 terabytes.
Error Message
Dec  3 09:26:48 holoship scsi: WARNING: /sbus@a,0/SUNW,socal@d,10000/
sf@1,0/ssd@w50020f23000002a4,0 (ssd1):
Dec  3 09:26:48 holoship disk has 2576941056 blocks, which is too large
for a 32-bit kernel
Cause
You attempted to boot a system running a 32-bit SPARC kernel with a disk greater than 1 terabyte.
Solution
Boot a system running a 64-bit SPARC kernel with a disk greater than 1 terabyte.
Error Message
Dec  3 09:12:17 holoship scsi: WARNING: /sbus@a,0/SUNW,socal@d,10000/
Dec  3 09:12:17 holoship corrupt label - wrong magic number
Cause
You attempted to add this disk to a system running an older Solaris release.
Solution
Add this disk to a system running the Solaris release that supports the EFI disk label.
Where to Find Disk Management Tasks
Use these references to find step-by-step instructions for managing disks.
Format a disk and examine a disk label
Chapter 11, Administering Disks (Tasks)
Add a new disk to a SPARC system
Add a new disk to an x86 system
Hot-Plug a SCSI or PCI disk
Chapter 6, Dynamically Configuring Devices (Tasks)
Overview of Disk Management
The management of disks in the Solaris environment usually involves setting up the system and running the Solaris installation program to create the appropriate disk slices and file systems and to install the operating system. Occasionally, you might need to use the format utility to add a new disk drive or replace a defective one.
Note –
The Solaris operating system runs on two types of hardware, or platforms—SPARC and x86. The Solaris operating system runs on both 64–bit and 32–bit address spaces. The information in this document pertains to both platforms and address spaces unless called out in a special chapter, section, note, bullet, figure, table, example, or code example.
Disk Terminology
Before you can effectively use the information in this section, you should be familiar with basic disk architecture. In particular, you should be familiar with the following terms:
Disk Term
Description
Track
A concentric ring on a disk that passes under a single stationary disk head as the disk rotates.
Cylinder
The set of tracks with the same nominal distance from the axis about which the disk rotates.
Sector
Section of each disk platter. A sector holds 512 bytes.
Block
A data storage area on a disk. A disk block is 512 bytes.
Disk controller
A chip and its associated circuitry that controls the disk drive.
Disk label
The first sector of a disk that contains disk geometry and partition information.
Device driver
A device driver is a kernel module that controls a hardware or virtual device.
For additional information, see the product information from your disk's manufacturer.
About Disk Slices
Files stored on a disk are contained in file systems. Each file system on a disk is assigned to a slice, which is a group of sectors set aside for use by that file system. Each disk slice appears to the operating system (and to the system administrator) as though it were a separate disk drive.
For information about file systems, see Chapter 15, Managing File Systems (Overview).
Note –
Slices are sometimes referred to as partitions. This book uses slice but certain interfaces, such as the format utility, refer to slices as partitions.
When setting up slices, remember these rules:
Slices are set up slightly differently on SPARC and x86 platforms. The following table summarizes the differences.
Table 10–1 Slice Differences on Platforms
SPARC Platform
x86 Platform
Whole disk is devoted to Solaris environment.
Disk is divided into fdisk partitions, one fdisk partition per operating system.
VTOC – Disk is divided into 8 slices, numbered 0–7.
EFI – Disk is divided into 7 slices, numbered 0–6.
VTOC – The Solaris fdisk partition is divided into 10 slices, numbered 0–9.
Solaris Volume Manager, previously Solstice DiskSuiteTM, has a partitioning feature, soft partitioning, that enables more than eight partitions per disk.
For general information about Solaris Volume Manager, see Chapter 2, Storage Management Concepts, in Solaris Volume Manager Administration Guide. For information on soft partitioning, see Chapter 12, Soft Partitions (Overview), in Solaris Volume Manager Administration Guide.
SPARC: Disk Slices
The following table describes the slices on a SPARC based system.
Table 10–2 SPARC: Customary Disk Slices
Slice
File System
Usually Found on Client or Server Systems?
Comments
0
root (/)
Both
Holds files and directories that make up the operating system.
EFI – You cannot boot from a disk with an EFI label.
1
swap
Both
Provides virtual memory, or swap space.
2
Both
VTOC – Refers to the entire disk, by convention. The size of this slice should not be changed.
EFI – Optional slice to be defined based on your site's needs.
3
/export
Both
Optional slice that can be defined based on your site's needs.
Can be used on a server to hold alternative versions of operating systems that are required by client systems.
4
Both
5
Both
Can be used to hold application software added to a system. If a slice is not allocated for the /opt file system during installation, the /opt directory is put in slice 0.
6
/usr
Both
Holds operating system commands (also known as executables). This slice also holds documentation, system programs (init and syslogd, for example) and library routines.
7
/home or
/export/home
Both
VTOC – Holds files that are created by users.
EFI – Not applicable.
8
N/A
N/A
VTOC – Not applicable.
EFI – A reserved slice created by default. This area is similar to the VTOC's alternate cylinders. Do not modify nor delete this slice.
x86: Disk Slices
On x86 based systems, disks are divided into fdisk partitions. An fdisk partition is a section of the disk that reserved for a particular operating system, such as the Solaris release.
The Solaris release places ten slices, numbered 0–9, on a Solaris fdisk partition as shown in the following table.
Table 10–3 x86: Customary Disk Slices
Slice
File System
Purpose
0
root (/)
Both
Holds the files and directories that make up the operating system.
1
swap
Both
2
Both
3
/export
Both
4
5
Both
6
/usr
Both
7
/home or /export/home
Both
8
Both
Contains information necessary for to boot the Solaris environment from the hard disk. The slice resides at the beginning of the Solaris fdisk partition (although the slice number itself does not indicate this fact), and is known as the boot slice.
9
Both
Provides an area that is reserved for alternate disk blocks. Slice 9 is known as the alternate sector slice.
Using Raw Data Slices
The SunOS operating system stores the disk label in block 0 of each disk. So, third-party database applications that create raw data slices must not start at block 0, or the disk label will be overwritten and the data on the disk will be inaccessible.
Do not use the following areas of the disk for raw data slices, which are sometimes created by third-party database applications:
Slice Arrangements on Multiple Disks
Although a single large disk can hold all slices and their corresponding file systems, two or more disks are often used to hold a system's slices and file systems.
Note –
A slice cannot be split between two or more disks. However, multiple swap slices on separate disks are allowed.
For instance, a single disk might hold the root (/) file system, a swap area, and the /usr file system, while another disk holds the /export/home file system and other file systems that contain user data.
In a multiple disk arrangement, the disk that contains the operating system software and swap space (that is, the disk that holds the root (/) and /usr file systems and the slice for swap space) is called the system disk. Other disks are called secondary disks or non-system disks.
When you arrange a system's file systems on multiple disks, you can modify file systems and slices on the secondary disks without having to shut down the system or reload operating system software.
When you have more than one disk, you also increase input-output (I/O) volume. By distributing disk load across multiple disks, you can avoid I/O bottlenecks.
Determining Which Slices to Use
When you set up a disk's file systems, you choose not only the size of each slice, but also which slices to use. Your decisions about these matters depend on the configuration of the system to which the disk is attached and the software you want to install on the disk.
System configurations that need disk space are as follows:
Each system configuration can use slices in a different way. The following table lists some examples.
Table 10–4 System Configurations and Slices
Slice
Servers
Standalone Systems
0
root
root
1
swap
swap
2
3
/export
6
/usr
/usr
7
/export/home
/home
For more information about system configurations, see Overview of System Types in System Administration Guide: Basic Administration.
Note –
The Solaris installation program provides default slice sizes based on the software you select for installation.
The format Utility
Read the following overview of the format utility and its uses before proceeding to the “how-to” or reference sections.
The format utility is a system administration tool that is used to prepare hard disk drives for use on your Solaris system.
The following table shows the features and associated benefits that the format utility provides.
Table 10–5 Features and Benefits of the format Utility
Feature
Benefit
Searches your system for all attached disk drives
Reports on the following:
  • Target location
  • Disk geometry
  • Whether the disk is formatted
  • If the disk has mounted partitions
Retrieves disk labels
Convenient for repair operations
Repairs defective sectors
Allows administrators to repair disk drives with recoverable errors instead of sending the drive back to the manufacturer
Formats and analyzes a disk
Creates sectors on the disk and verifies each sector
Partitions a disk
Divides a disk into slices so individual file systems can be created on separate slices
Labels a disk
Writes disk name and configuration information to the disk for future retrieval (usually for repair operations)
The format utility options are fully described in Chapter 14, The format Utility (Reference).
When to Use the format Utility
Disk drives are partitioned and labeled by the Solaris installation program when you install the Solaris release. You can use the format utility to do the following:
The main reason a system administrator uses the format utility is to divide a disk into disk slices. These steps are covered in Chapter 12, SPARC: Adding a Disk (Tasks) and Chapter 13, x86: Adding a Disk (Tasks).
See the following section for guidelines on using the format utility.
Guidelines for Using the format Utility
Table 10–6 The format Utility Guidelines
Task
Guidelines
Format a disk
  • Any existing data is destroyed when you reformat a disk.
  • The need for formatting a disk drive has dropped as more and more manufacturers ship their disk drives formatted and partitioned. You might not need to use the format utility when you add a disk drive to an existing system.
  • If a disk has been relocated and is displaying a lot of disk errors, you can attempt to reformat it, which will automatically remap any bad sectors.
How to Format a Disk
Replace a system disk
  • Data from the damaged system disk must be restored from a backup medium. Otherwise, the system will have to be reinstalled by using the installation program.
SPARC: How to Connect a System Disk and Boot or x86: How to Connect a System Disk and Boot or, if the system must be reinstalled, Solaris 9 9/04 Installation Guide
Divide a disk into slices
  • Any existing data is destroyed when you repartition and relabel a disk with existing slices.
  • Existing data must be copied to backup media before the disk is repartitioned and restored.
SPARC: How to Create Disk Slices and Label a Disk or x86: How to Create Disk Slices and Label a Disk
Add a secondary disk to an existing system
  • Any existing data must be restored from backup media if the secondary disk is reformatted or repartitioned.
SPARC: How to Connect a Secondary Disk and Boot or x86: How to Connect a Secondary Disk and Boot
Repair a disk drive
  • Some customer sites prefer to replace rather than repair defective drives. If your site has a repair contract with the disk drive manufacturer, you might not need to use the format utility to repair disk drives.
  • The repair of a disk drive usually means that a bad sector is added to a defect list. New controllers remap bad sectors automatically with no system interruption.
  • If the system has an older controller, you might need to remap a bad sector and restore any lost data.
Repairing a Defective Sector
Formatting a Disk
In most cases, disks are formatted by the manufacturer or reseller. So, they do not need to be reformatted when you install the drive. To determine if a disk is formatted, use the format utility. For more information, see How to Determine if a Disk is Formatted.
If you determine that a disk is not formatted, use the format utility to format the disk.
When you format a disk, you accomplishes two steps:
Caution – Caution –
Formatting a disk is a destructive process because it overwrites data on the disk. For this reason, disks are usually formatted only by the manufacturer or reseller. If you think disk defects are the cause of recurring problems, you can use the format utility to do a surface analysis. However, be careful to use only the commands that do not destroy data. For details, see How to Format a Disk.
A small percentage of total disk space that is available for data is used to store defect and formatting information. This percentage varies according to disk geometry, and decreases as the disk ages and develops more defects.
Formatting a disk might take anywhere from a few minutes to several hours, depending on the type and size of the disk.
About Disk Labels
A special area of every disk is set aside for storing information about the disk's controller, geometry, and slices. That information is called the disk's label. Another term that is used to described the disk label is the VTOC (Volume Table of Contents) on a disk with a VTOC label. To label a disk means to write slice information onto the disk. You usually label a disk after you change its slices.
If you fail to label a disk after you create slices, the slices will be unavailable because the operating system has no way of “knowing” about the slices.
Partition Table
An important part of the disk label is the partition table, which identifies a disk's slices, the slice boundaries (in cylinders), and the total size of the slices. You can display a disk's partition table by using the format utility. The following table describes partition table terminology.
Table 10–7 Partition Table Terminology
Partition Term
Value
Description
Number
0-7
VTOC – Partitions or slices, numbered 0–7.
EFI – Partitions or slices, numbered 0–6.
Tag
0=UNASSIGNED 1=BOOT 2=ROOT 3=SWAP 4=USR 5=BACKUP 7=VAR 8=HOME 11=RESERVED
A numeric value that usually describes the file system mounted on this partition.
Flags
wm
The partition is writable and mountable.
wu rm
The partition is writable and unmountable. This is the default state of partitions that are dedicated for swap areas. (However, the mount command does not check the “not mountable” flag.)
rm
The partition is read only and mountable.
Partition flags and tags are assigned by convention and require no maintenance.
For more information on displaying the partition table, see How to Display Disk Slice Information or How to Examine a Disk Label.
Displaying Partition Table Information
The following is an example of a partition table from a 4.0-Gbyte disk with a VTOC label displayed from the format utility:
Total disk cylinders available: 8892 + 2 (reserved cylinders)
Part      Tag    Flag     Cylinders        Size            Blocks
  0       root    wm    1110 - 4687        1.61GB    (0/3578/0) 3381210
  1       swap    wu       0 - 1109      512.00MB    (0/1110/0) 1048950
  2     backup    wm       0 - 8891        4.01GB    (0/8892/0) 8402940
  3 unassigned    wm       0               0         (0/0/0)          0
  4 unassigned    wm       0               0         (0/0/0)          0
  5 unassigned    wm       0               0         (0/0/0)          0
  6 unassigned    wm       0               0         (0/0/0)          0
  7       home    wm    4688 - 8891        1.89GB    (0/4204/0) 3972780
The partition table displayed by the format utility contains the following information:
Column Name
Description
Part
Partition (or slice number). See Table 10–7 for a description of this column.
Tag
Partition tag. See Table 10–7 for a description of this column.
Flags
Partition flag. See Table 10–7 for a description of this column.
Cylinders
The starting and ending cylinder number for the slice.
Size
The slice size in Mbytes.
Blocks
The total number of cylinders and the total number of sectors per slice in the far right column.
First Sector
EFI – The starting block number.
Last Sector
EFI – The ending block number.
The following is an example of a EFI disk label displayed by using the prtvtoc command.
# prtvtoc /dev/rdsk/c4t1d0s0
* /dev/rdsk/c4t1d0s0 partition map
* Dimensions:
*     512 bytes/sector
* 2576941056 sectors
* 2576940989 accessible sectors
* Flags:
*   1: unmountable
*  10: read-only
*                           First     Sector    Last
* Partition  Tag  Flags     Sector     Count    Sector   Mount Directory
       0      2    00          34   629145600  629145633
       1      4    00   629145634   629145600 1258291233
       6      4    00  1258291234  1318633404 2576924637
       8     11    00  2576924638       16384 2576941021
* Flags:
*   1: unmountable
*  10: read-only
The prtvtoc command provides the following information:
Column Name
Description
Dimensions
This section describes the physical dimensions of the disk drive.
Flags
This section describes the flags listed in the partition table section. For a description of partition flags, see Table 10–7.
Partition (or Slice) Table
This section contains the following information:
Partition
Partition (or slice number). For a description of this column, see Table 10–7.
Tag
Partition tag. For a description of this column, see Table 10–7.
Flags
Partition flag. For a description of this column, see Table 10–7.
First Sector
The first sector of the slice.
Sector Count
The total number of sectors in the slice.
Last Sector
The last sector of the slice.
Mount Directory
The last mount point directory for the file system.
Dividing a Disk Into Slices
The format utility is most often used by system administrators to divide a disk into slices. The steps are as follows:
The easiest way to divide a disk into slices is to use the modify command from the partition menu of the format utility. The modify command allows you to create slices by specifying the size of each slice without having to keep track of the starting cylinder boundaries. The modify command also keeps tracks of any disk space that remains in the “free hog” slice.
Using the Free Hog Slice
When you use the format utility to change the size of one or more disk slices, you designate a temporary slice that will expand and shrink to accommodate the resizing operations.
This temporary slice donates, or “frees,” space when you expand a slice, and receives, or “hogs,” the discarded space when you shrink a slice. For this reason, the donor slice is sometimes called the free hog.
The free hog slice exists only during installation or when you run the format utility. There is no permanent free hog slice during day-to-day operations.
For information on using the free hog slice, see SPARC: How to Create Disk Slices and Label a Disk or x86: How to Create Disk Slices and Label a Disk.
