Become superuser or assume an equivalent role.
Create a file system for each slice.
# newfs /dev/rdsk/cwtxdysz |
/dev/rdsk/cwtxdysx is the raw device for the file system to be created.
For more information about the newfs command, see Chapter 16, Creating UFS, TMPFS, and LOFS File Systems (Tasks) or newfs(1M).
Verify the new file system by mounting it.
# mount /dev/dsk/cwtxdysz /mnt # ls lost+found |
System Disk – You need to restore the root (/) and /usr file systems on the disk. Go to Chapter 25, Restoring Files and File Systems (Tasks).
After the root (/) and /usr file systems are restored, install the boot block. Go to SPARC: How to Install a Boot Block on a System Disk.
Secondary Disk – You might need to restore file systems on the new disk. Go to Chapter 25, Restoring Files and File Systems (Tasks). If you are not restoring file systems on the new disk, you are finished adding a secondary disk.
For information on making the file systems available to users, see Chapter 17, Mounting and Unmounting File Systems (Tasks).
