System Administration Guide: Devices and File Systems
ProcedureSPARC: How to Connect a System Disk and Boot
This procedure assumes that the system is shut down.
Steps
  1. Disconnect the damaged system disk from the system.
  2. Make sure that the disk you are adding has a different target number than the other devices on the system.
    You will often find a small switch located at the back of the disk for this purpose.
  3. Connect the replacement system disk to the system and check the physical connections.
    Refer to the disk's hardware installation guide for installation details.
  4. Follow the instructions in the following table, depending on whether you are booting from a local Solaris CD or DVD or a remote Solaris CD or DVD from the network.
    Boot Type
    Action
    From a Solaris CD or DVD in a local drive
    1. Make sure the CD or DVD is in the drive.
    2. Boot from the media to single-user mode:
    ok boot cdrom -s
    From the network
    Boot from the network to single-user mode:
    ok boot net -s
    After a few minutes, the root prompt (#) is displayed.
See Also
After you boot the system, you can create slices and a disk label on the disk. Go to SPARC: How to Create Disk Slices and Label a Disk.
