System Administration Guide: Devices and File Systems
x86: Guidelines for Creating an fdisk Partition
Follow these guidelines when you set up the fdisk partition.
x86 only –
Solaris slices are sometimes called partitions. This book uses the term slice, but some Solaris documentation and programs might refer to a slice as a partition.
To avoid confusion, Solaris documentation tries to distinguish between fdisk partitions (which are supported only on Solaris (x86 Platform Edition)) and the divisions within the Solaris fdisk partition, which might be called slices or partitions.
