System Administration Guide: Devices and File Systems
Troubleshooting cachefspack Errors
You might see the following error messages when you use the cachefspack command.
cachefspack: pathname - can't open directory: permission denied
Cause
You might not have the correct permissions to access the file or directory.
Action
Set the correct permissions.
cachefspack: pathname - can't open directory: no such file or
directory
Cause
You might not have the correct file or directory.
Action
Check for a possible typo.
cachefspack: pathname - can't open directory: stale NFS file handle
Cause
The file or directory might have been moved or deleted from the server at the time you attempted to access it.
Action
Verify that the file or directory on the server is still accessible.
cachefspack: pathname - can't open directory: interrupted system
call
Cause
You might have inadvertently pressed Control-C while issuing the command.
Action
Reissue the command.
cachefspack: pathname - can't open directory: I/O error
Cause
You might have a hardware problem.
Action
Check your hardware connections.
cachefspack: error opening dir
Cause
You might not have the correct file or directory. The path identified after the BASE command in the file format could be a file and not a directory. The path specified must be a directory.
Action
Check for a possible typo. Check the path identified after the BASE command in your file format. Make sure the path identifies a directory, not a file.
cachefspack: unable to get shared objects
Cause
The executable might be corrupt or in a format that is not recognizable.
Action
Replace the executable.
cachefspack: filename - can't pack file: permission denied
Cause
Action
cachefspack: filename - can't pack file: no such file or directory
Cause
Action
cachefspack: filename- can't pack file: stale NFS file handle
Cause
Action
cachefspack: filename- can't pack file: interrupted system call
Cause
Action
cachefspack: filename- can't pack file: I/O error
Cause
Action
cachefspack: filename- can't pack file: no space left on device.
Cause
The cache is out of disk space.
Action
You need to increase the size of the cache by increasing disk space.
cachefspack: filename - can't unpack file: permission denied
Cause
Action
cachefspack: filename - can't unpack file: no such file or directory
Cause
Action
cachefspack: filename- can't unpack file: stale NFS file handle
Cause
Action
cachefspack: filename - can't unpack file: interrupted system call
Cause
You might have pressed Control-C inadvertently while issuing the command.
Action
cachefspack: filename- can't unpack file I/O error
Cause
Action
cachefspack: only one `d', `i', `p', or `u' option allowed
Cause
You entered more than one of these options in a command session.
Action
Select one option for the command session.
cachefspack: can't find environment variable.
Cause
You forgot to set a corresponding environment variable to match the $ in your configuration file.
Action
Define the environment variable in the proper location.
cachefspack: skipping LIST command - no active base
Cause
A LIST command is present in your configuration file that has no corresponding BASE command.
Action
Define the BASE command.
