System Administration Guide: Devices and File Systems
High-Level View of Using the CacheFS File System (Task Map)
Use this task map to identify all the tasks for using CacheFS file systems. Each task in this map points to a series of additional tasks such as creating and mounting the CacheFS file systems, and packing and maintaining the cache.
Task
Description
For Instructions
1. Create and mount a CacheFS file system
Create the cache and mount the file system in the cache.
Creating and Mounting a CacheFS File System (Task Map)
2. Maintain a CacheFS file system
Display and modify a CacheFS file system by unmounting, removing, or re-creating the cache.
Maintaining a CacheFS File System (Task Map)
3. (Optional) Pack and unpack a CacheFS file system
Determine whether you want to pack the cache and use packing lists. Packing the cache ensures that certain files and directories are always updated in the cache.
Packing a Cached File System (Task Map)
4. Collect CacheFS statistics
Determine cache performance and appropriate cache size.
Collecting CacheFS Statistics (Task Map)
