After a CacheFS file system is set up, it requires little maintenance. Use the optional procedures in this table if you need to perform maintenance tasks on your CacheFS file systems.
 Task  |
 Description  |
 For Instructions  |
 1. Modify a CacheFS file system  |
 Modify CacheFS file system behavior by unmounting, deleting, or re-creating the cache.  | |
 2. Display CacheFS file system information  |
 Display information about CacheFS file systems by using the cfsadmin command.  | |
 3. Perform consistency checking  |
 Perform consistency checking on demand by using the cfsadmin command.  | |
 4. Delete a CacheFS file system  |
 Delete a CacheFS file system by using the umount command and the cfsadmin command.  | |
 5. Check the integrity of a CacheFS file system  |
 Check the integrity of a CacheFS file system by using the fsck_cachefs command.  |
