System Administration Guide: Devices and File Systems
ProcedureHow to Set Up CacheFS Logging
Steps
  1. Set up logging.
    $ cachefslog -f log-file-path /mount-point
    -f
    Sets up logging.
    log-file-path
    Specifies the location of the log file. The log file is a standard file you create with an editor, such as vi.
    /mount-point
    Designates the mount point (CacheFS file system) for which statistics are being collected.
  2. Verify that you correctly set up the log file.
    $ cachefslog /mount-point
Example 18–12 Setting Up CacheFS Logging
The following example shows how to set up the /var/tmp/samlog log file to collect statistics about the /home/sam directory.
$ cachefslog -f /var/tmp/samlog /home/sam
  /var/tmp/samlog: /home/sam
